It is currently Thu Aug 07, 2025 5:06 am
 Post subject: Bumps in finish
PostPosted: Mon Mar 26, 2018 2:40 pm
First name: David
City: Napa
Zip/Postal Code: 94558
Anyone know what this might be? Im spraying lacquer and am wondering if its moisture? Ive sanding them down 2 times and resprayed and they keep popping up.
 Post subject: Re: Bumps in finish
PostPosted: Mon Mar 26, 2018 2:56 pm
Last Name: Cox
Do they keep popping up in exactly the same spots? If you sand one down very carefully - look with a good light shining across the finish and see if you see a fine little whisp of hair/fuzz sticking up.. If so - it's dust/lint/hairs.... Groan...
Let's just say that in my context - "The hair of the dog" refers to special inclusions in my finishes, not something fun the night before. ;)
PostPosted: Mon Mar 26, 2018 3:10 pm
I also noticed that dandruff would get into lacquer finish. In my example, the final leveling and buff out left them not visible.
PostPosted: Mon Mar 26, 2018 3:42 pm
That looks like "solvent pop". This is caused by the finish curing before the solvent has had a chance to escape. A bit of retarder in the lacquer will fix this.
Last edited by Barry Daniels on Mon Mar 26, 2018 4:23 pm, edited 3 times in total.
PostPosted: Mon Mar 26, 2018 3:45 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
If viewed with a 10x hand magnifier, do they look like volcanoes or mountains? Something that looks like a raised ring with a depression in the center might be an open pore or (if a bit larger that what is evident in your shot) a fisheye, while a mountain-like hump is probably dust or other debris. You might consider scraping level before shooting the next coat in either case.
- Beth Brower
PostPosted: Mon Mar 26, 2018 9:55 pm
First name: David
City: Napa
I scraped and sanded them down then they reappeared when I shot a new coat...... grrrrrr. Ok I think I'll try the retarder.
I sprayed out about 40 other cabinet doors with out any problems and the raised bumps was random fyi
PostPosted: Mon Mar 26, 2018 10:16 pm
Solvent popping usually occurs during hot weather when the lacquer cures quicker. Sherwin Williams sells a special lacquer thinner with some retarder added to handle the summer season here in Houston. Or you can buy a can of retarder and add it yourself.
Last edited by Barry Daniels on Wed Mar 28, 2018 10:31 am, edited 1 time in total.
PostPosted: Tue Mar 27, 2018 8:15 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
Did you shoot in the sun? Temp? RH? All 40 doors received the same sand and fill?
- Beth Brower
PostPosted: Thu Mar 29, 2018 3:44 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Solvent pop.
Here is a handy problem solving chart I made for spray finishes. https://howardguitars.blogspot.com/2015 ... rt_18.html
Brian
These users thanked the author B. Howard for the post: Clinchriver (Thu Mar 29, 2018 6:38 am)
PostPosted: Fri Mar 30, 2018 9:44 pm
First name: David
City: Napa
Thanks for the info fellas mucho gracious
PostPosted: Fri Mar 30, 2018 9:45 pm
First name: David
City: Napa
I was shooting in the shade. it was a bit on the cold side like maybe 60-65ish.
PostPosted: Fri Mar 30, 2018 11:05 pm
I've had that happen when I've sprayed a finish in a cold environment and taken it to dry in a warm environment (to avoid blushing). I blame it on the piece losing moisture trying to regain equilibrium with the relative humidity in the new (dryer) environment. The moisture coming out of the wood's pores causing the air bubbles as the finish cures.
